I have a top loading whirlpool which runs all the way through all cycles. As the spin cycle ends although it makes a loud clicking/ratchiting sound until it comes to a stop. Any help will be appreciated. Steve
Check the spin basket, does it feel loose?
The resistance seems normal.
The correct model number islsq9600lw1
You were correct-it was the drive block. The tabs on the spin tube needed to be bent back out as well. Thank You!
Originally Posted by: steveandpeggy  You were correct-it was the drive block. The tabs on the spin tube needed to be bent back out as well. Thank You! this is the first time i'm using this site. i have the same problem with my whirlpool washer. is it an expensive fix?
Drive block was $15.00 at my local appliance store.
Be careful if you have this problem. If you let it go too long, the tabs on the spin tube will get a slant and it will require replacement of the spin tube, a messy job with turbine oil and $68 cost for new spin tube. Best to use the special spanner wrench for this job.
