steveandpeggy
#1 Posted : Wednesday, August 6, 2008 10:39:12 PM(UTC)
steveandpeggy
I have a top loading whirlpool which runs all the way through all cycles. As the spin cycle ends although it makes a loud clicking/ratchiting sound until it comes to a stop. Any help will be appreciated.
Steve
#2 Posted : Thursday, August 7, 2008 1:54:36 AM(UTC)
Check the spin basket, does it feel loose?
steveandpeggy
#3 Posted : Thursday, August 7, 2008 8:26:27 AM(UTC)
steveandpeggy
The resistance seems normal.
steveandpeggy
#4 Posted : Thursday, August 7, 2008 9:36:48 AM(UTC)
steveandpeggy
The correct model number islsq9600lw1
steveandpeggy
#5 Posted : Sunday, August 17, 2008 5:47:17 PM(UTC)
steveandpeggy
You were correct-it was the drive block. The tabs on the spin tube needed to be bent back out as well. Thank You!
francine
#6 Posted : Wednesday, August 20, 2008 2:59:38 PM(UTC)
francine
this is the first time i'm using this site. i have the same problem with my whirlpool washer. is it an expensive fix?
steveandpeggy
#7 Posted : Wednesday, August 20, 2008 3:51:59 PM(UTC)
steveandpeggy
Drive block was $15.00 at my local appliance store.
#8 Posted : Wednesday, August 20, 2008 4:10:08 PM(UTC)
Be careful if you have this problem. If you let it go too long, the tabs on the spin tube will get a slant and it will require replacement of the spin tube, a messy job with turbine oil and $68 cost for new spin tube.
Best to use the special spanner wrench for this job.
