Carl Feil
#1 Posted : Tuesday, August 19, 2008 9:11:01 AM(UTC)
Carl Feil
Hello. The problem with the gas dryer is this: The timer has different settings and we always turn the timer knob to the left close the door and push start. When we set the timer you can usually hear(faintly) the timer working, now we cant. I put a load of clothes in at night(yesterday) and woke the next morning and the dryer was still on. I felt no heat from the dryer and the timer was in the same position as when I left it the night before. I ran the dryer again for ten minutes, but this time I set the timer on the right side of the knob and the timer worked but no heat at all. Hopefully you can help me with a solution. Thanks Carl
kayakcrzy
#2 Posted : Wednesday, August 20, 2008 4:54:06 AM(UTC)
kayakcrzy
You have 1 of 2 problems. If you take the back of the dryer off, you will see a thermal fuse. It will be white in color, and a inch and a half long, by a half inch wide. Unplug the dryer, and take the 2 wires off of it, and put the terminal ends together, and put some tape around it so it does not hit metal, and turn the dryer on. If it works replace the thermal fuse. DO NOT RUN the dryer with the fuse jumped out, this is for testing only, because it is the only thing between you and that dryer burning down the house. If it does not work, replace the ignitor. Tom ApplianceEducator.comApplianceEducator.com
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
Kenmore gas dryer model 110.96742701 (Dryer Repair)
by Guest 2/8/2024 9:07:42 AM(UTC)
Maytag MDG8400AWW gas dryer not drying clothes (Dryer Repair)
by tvr4 12/31/2023 2:45:43 PM(UTC)
Samsung Gas Dryer - Model DVG50M7450* (Dishwasher Repair)
by Carl B 10/26/2023 2:05:00 PM(UTC)
Alternate T-stat for Speed Queen gas dryer (Dryer Repair)
by Guest 10/14/2023 12:59:47 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Drum repair of old Speed Queen gas dryer (Dryer Repair)
by Guest 3/13/2023 7:58:37 AM(UTC)
DLGX8001W gas dryer clicks on control board but wont start (Dryer Repair)
by Guest 3/12/2023 10:17:53 AM(UTC)
