Originally Posted by: Joe / APP Team  Don, Got your jpeg image, That clip appears to be part of the "spin tube" basket drive assembly. It is part #3 in the parts diagram Part number: AP4260762
and is located below the bottom "spider" plate of the tube assembly, above the guard ring and clutch pads. I hope this helps. :) :) :) Thanks a million Joe that was it! Everything else looks great! I'll let you know when it works, ha ha ha. You have been a great help !!! Don
Don Don, You've done a great job(and all the work). Yes, please let us know when your up and running. :) :) :)
and is located below the bottom "spider" plate of the tube assembly, above the guard ring and clutch pads. I hope this helps. :) :) :) Thanks again Joe for all your help. everything is back together and working just fine. Ran two loads already and there is no unsual noise. The problem was the gear and spline at the lower end of the agitator shaft. I replaced the whole shaft assembly, reassembled the gearcase and it is perfect. Thanks again. Don
Originally Posted by: drc-clwtr  Thanks again Joe for all your help. everything is back together and working just fine. Ran two loads already and there is no unsual noise. The problem was the gear and spline at the lower end of the agitator shaft. I replaced the whole shaft assembly, reassembled the gearcase and it is perfect. Thanks again.
Don That's an even greater accomplishment, You've got skills ... as they say. :cool: :cool: :cool:
