tjwash5
#1 Posted : Wednesday, November 17, 2010 7:14:19 AM(UTC)
tjwash5
My whirpool electric dryer goes on when I hit the start button but doesen't stay on. If I hold down the start button it will stay on but once I let it go it shuts off. I've replaced the switch but same thing happens. Any suggestions would be appreciated. Thanks Tom
#2 Posted : Wednesday, November 17, 2010 9:42:10 AM(UTC)
A model number may help others help you.
Usually the motor centrifugal switch closes when the motor gets close to operating speed and this provides a parallel path to the start switch.
So you can release the start switch and the motor keeps running.
Do you get heat when you hold the start switch in.
The motor also has a second centrifugal switch which turns tje heater on.
So if you do not get heat when the motor is running it could be that the centrifugal mechanism in the motor is not activating the switches.
May be just dirty and/or clogged solid with lint.
tjwash5
#3 Posted : Wednesday, November 17, 2010 10:13:23 AM(UTC)
tjwash5
The model number is LER5636PQO and I taped the start switch down and the dryer dries perfectly. I was concerned this could be fire hazard. Any further thoughts Thank You Tomuote=denman;302889]A model number may help others help you.
#4 Posted : Thursday, November 18, 2010 12:08:53 AM(UTC)
Sounds like either the centrifugal switch on the motor is toast or you have a loose/off wire.
Whirlpool dryer WED7500VW1 won’t turn on (Dryer Repair)
by tryingmybest 11/15/2023 4:40:47 PM(UTC)
Whirlpool dryer wire (Dryer Repair)
by Guest 10/20/2023 10:51:08 AM(UTC)
Whirlpool dryer heavy load turning (Dryer Repair)
by Guest 3/28/2023 5:58:08 PM(UTC)
YWED7500VW0 - Looking whirlpool dryer belt access procedure (Dryer Repair)
by Toronto_18_2703 11/4/2022 12:46:25 PM(UTC)
Whirlpool Dryer Knocking Noise (Dryer Repair)
by Guest 8/31/2022 5:01:42 PM(UTC)
Whirlpool Dryer sensor light on and never starts (Dryer Repair)
by CPepe 8/27/2022 11:48:56 AM(UTC)
Whirlpool Dryer WGD5300SQ0 taking too long to dry (Dryer Repair)
by aryan 4/10/2022 3:24:26 PM(UTC)
Whirlpool Dryer Model# W10151592A (Dryer Repair)
by Ssuarez 2/28/2022 4:22:11 PM(UTC)
Whirlpool dryer WED9500TW1 (Dryer Repair)
by Herm404 12/18/2021 12:39:46 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Whirlpool Dryer Fan Not Working (Dryer Repair)
by kkknie 11/21/2021 12:09:24 PM(UTC)
Whirlpool Dryer WED5790VQ1 (Dryer Repair)
by Guest 10/22/2021 3:39:17 PM(UTC)
whirlpool dryer codes persist (Dryer Repair)
by JMM12 7/30/2021 4:52:44 AM(UTC)
whirlpool dryer stops on sensing (Dryer Repair)
by Guest 5/16/2021 7:46:23 PM(UTC)
Whirlpool dryer---need to hold start button several seconds (Dryer Repair)
by pjlarivi 2/13/2021 10:44:25 AM(UTC)
