shepp59
#1 Posted : Wednesday, November 17, 2010 8:21:51 AM(UTC)
shepp59
Hello. trying to determine the steps to repair my oven. local repair people are reluctant to come out and keep advising me to buy parts in a ( poke and hope) scenerio. getting specific fault codes of f5 on the top oven and fr on the bottom. This site does not list my model to suggest what to do in regards to these fault codes. Any suggestions?
#2 Posted : Wednesday, November 17, 2010 5:20:42 PM(UTC)
There are two relay boards (one for each oven). They both are located behind the control panel on the right side.
There is an oven temperature sensor in each oven.
The "F5" error code means "Power to element relays disabled in cook mode". Check the oven sensor plugs and all relay board wire harness for a tight connections.
The "FR" error code for the lower oven has the same meaning and requires the same actions.
In case if there is nothing wrong found, replace both relay boards.
- The upper oven relay board Part number: AP4098257
shepp59
#3 Posted : Thursday, November 18, 2010 5:34:26 AM(UTC)
shepp59
Thank you, i have already done that and to no avail. i will order the part
#4 Posted : Thursday, November 18, 2010 4:20:16 PM(UTC)
How do you find fault codes for dishwasher (Dishwasher Repair)
by cincyceliac1 11/29/2015 5:34:06 PM(UTC)
Oven does not work but no fault codes? (Oven Repair (including Ranges and Cooktops))
by Ruby roars 6/5/2015 10:52:55 AM(UTC)
Whirlpool Fault Codes F01 & F00 (Washer Repair)
by little_gurney 7/6/2014 8:14:58 PM(UTC)
Fault codes F7 and F3 (Oven Repair (including Ranges and Cooktops))
by Sgavin 10/2/2013 8:30:30 AM(UTC)
ERSD F2 & F4 Fault codes (Oven Repair (including Ranges and Cooktops))
by mlb2332 5/24/2013 12:11:29 PM(UTC)
Multiple Fault Codes (Oven Repair (including Ranges and Cooktops))
by 79bronco 4/1/2013 6:31:42 AM(UTC)
whirlpool fault codes (Oven Repair (including Ranges and Cooktops))
by markkim12345 1/18/2013 6:57:27 AM(UTC)
How to Reset Miele fault codes (Dishwasher Repair)
by dan.stewart 2/19/2012 6:34:13 AM(UTC)
Whirlpool Cabrio getting F50 F51 fault codes (Washer Repair)
by dbergquist 1/24/2012 5:34:20 PM(UTC)
kitchenaid washer throwing fault codes (Washer Repair)
by buldog9 1/18/2012 11:45:18 AM(UTC)
Maytag Fault Codes (Washer Repair)
by rcoalson 6/29/2011 7:39:08 AM(UTC)
by rjreiner 3/13/2011 1:46:38 PM(UTC)
REd E6 and Light-Blue F2 Appliance Fault Codes (Oven Repair (including Ranges and Cooktops))
by Col. L. R. Hughes, AF Ret 4/16/2009 8:26:30 PM(UTC)
Fault Codes and Beeps (Oven Repair (including Ranges and Cooktops))
by hesper73 3/31/2009 4:40:47 AM(UTC)
Maytag Erratic Temperature, no fault codes (Oven Repair (including Ranges and Cooktops))
by Dan0 3/26/2009 7:14:43 AM(UTC)
