raptor
#1 Posted : Tuesday, November 16, 2010 9:11:45 AM(UTC)
raptor
Sounds like it is stuck in the 1st setting and the timer will stay on the same number for long periods of time . The machine does fill and the heat is working . Any help would be appreciated.
magician59
#2 Posted : Tuesday, November 16, 2010 10:13:03 AM(UTC)
magician59
Check the temperature of the water at the tap. It should be at least 120 degrees. Does this happen in all selected cycles? Here's a break down of the control panel parts. You may possibly find a bad wiring connection. Also look for any cracks or breaks in the communication ribbon from the touch pad to the control board. Disconnect the ribbon from the board (Unplug the wsher, or turn it off at the breaker, first) and clean the contacts at the end of the ribbon very gently, using a fresh pencil eraser. If all this fails, replace the control board. (Part #11 on the diagram)
Control panel parts replacement parts for WHIRLPOOL GU2500XTPB3 Undercounter Dishwasher | AppliancePartsPros.com
raptor
#3 Posted : Tuesday, November 16, 2010 11:36:34 AM(UTC)
raptor
thanks I will give that a try
raptor
#4 Posted : Tuesday, November 16, 2010 1:22:19 PM(UTC)
raptor
I was just told on top of the other issues mentioned it sounds like an electric leaf blower does that make a difference what would make it sound like that?
magician59
#5 Posted : Wednesday, November 17, 2010 5:23:48 AM(UTC)
magician59
The only noise maker should be the motor. I would check the filter and food chopper under the bottom spray arm to see that there is no broken glass, or debris. Those things will tend to make a lot of unusual noises. Some times the pump or motor will growl, if there are obstructions or any other resistance to draining.
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Cafe induction range issue... Help please! (Oven Repair (including Ranges and Cooktops))
by Guest 1/29/2023 7:31:31 PM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Help please (Oven Repair (including Ranges and Cooktops))
by wolfmanTX 11/2/2017 10:55:06 AM(UTC)
Dryer help please (Dryer Repair)
by Juliebolson 5/30/2017 12:34:48 AM(UTC)
by Jenjudd2 7/1/2015 3:18:27 PM(UTC)
Whirlpool fridge help please (Refrigerator & Freezer Repair)
by The Hurricane 3/25/2015 5:35:41 PM(UTC)
Newbe - Refrig/Freezer Help Please596.50694000 (Refrigerator & Freezer Repair)
by rodnogdog 2/22/2015 7:53:20 AM(UTC)
~*~Help please. Amana20 Cool not Cold. Any trouble shooting tips please~*~ (Refrigerator & Freezer Repair)
by PeterB. 9/2/2014 3:18:01 AM(UTC)
~*~Newbie. Could use some help please~*~ (Washer Repair)
by PeterB. 6/20/2014 6:57:51 AM(UTC)
Water Dispenser Sticks in On Position! Help Please? (Refrigerator & Freezer Repair)
by crosby1 3/16/2014 12:24:58 PM(UTC)
Whirlpool washer help please (Washer Repair)
by jcnitram 1/16/2014 7:10:15 PM(UTC)
by dshoff 1/8/2014 6:04:22 AM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
by sheriowaso 11/15/2013 4:21:37 PM(UTC)
