jim tomczak
#1 Posted : Sunday, November 14, 2010 10:28:44 AM(UTC)
jim tomczak
checked high limt,got 240 of both poles,check thermostat relay 120 off each
pole to ground but no 240 to each pole. my guess the thermo is blown
#2 Posted : Sunday, November 14, 2010 10:53:15 AM(UTC)
[COLOR="Blue"]checked high limt,got 240 of both poles,check thermostat relay 120 off each
pole to ground but no 240 to each pole. my guess the thermo is blown[/COLOR]
You will never see 240 volts when referenced to Neutral/ground.
Also do not know what a "thermostat relay" is.
If the unit is on and you measure 240 volts across the thermostat then it is toast.
If the contacts were closed you should read 0 volts.
Not sure how you are measuring.
You would be better off unplugging the unit and the wire to one side of the thermostat. Then measure across it for resistance, should be 0 ohms.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
