pdempsey
#1 Posted : Tuesday, November 9, 2010 12:54:46 PM(UTC)
pdempsey
My dryer runs and heats but soon after it blows the breaker. It is on a 220 and the only thing on that circuit. What could it be?
magician59
#2 Posted : Tuesday, November 9, 2010 1:20:09 PM(UTC)
magician59
It could be as simple as a weak breaker. Do you own, or have access to an ammeter? If you do, test the amps drawn by the dryer as it is running. It should be well within 30.
pdempsey
#3 Posted : Thursday, November 11, 2010 8:55:15 AM(UTC)
pdempsey
The dryer is on 2 20 amp breakers. It is tripping those. Should it be only on 1 30 amp. What do they recommend for the size of the breaker.
magician59
#4 Posted : Thursday, November 11, 2010 9:13:25 AM(UTC)
magician59
By the National Electric Code, an electric dryer needs to be on its own circuit, protected by a (double) 30-Amp breaker. The motor and control circuit runs off one side of that double; and the heat circuit uses the other.
For your safety, it might be a good idea to have an electrician check to make sure your house is within code.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
