emily1
#1 Posted : 17 years ago
emily1
My freezer door will not stay shut. We have cleaned out the freezer completely, and this has not helped. Even if it seems to close, when we open and close the fridge door the freezer door will pop open. Is this likely to be a gasket problem?
Thanks for the help.
#2 Posted : 17 years ago
Make sure the freezer door is not sagging. Door magnetic gasket must fully mate with the metal frame of freezer. If ok, check under door for torn gasket.
If ok, you can try to re-form the door gasket with a hair dryer, then before bedtime, duck tape the door closed with the gasket pushed in further. Next morning, remove tape, door should now be ok.
If still bad, replace door gasket. You can click on model # above to get part #.
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 10 months ago
Removal of French Freezer door on Frigidaire Gallery (Refrigerator & Freezer Repair)
by Guest 2 years ago
Refrigerator and Freezer Doors (Refrigerator & Freezer Repair)
by AeroncaChief 2 years ago
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 2 years ago
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3 years ago
Refrigerator and freezer door lights reversed - KitchenAid KSCS25FJSS (Refrigerator & Freezer Repair)
by blacter 3 years ago
Freezer door/drawer not closing (Refrigerator & Freezer Repair)
by mwarney 3 years ago
How to disassemble the freezer door (Refrigerator & Freezer Repair)
by cparke 3 years ago
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 4 years ago
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 4 years ago
Replace water line in freezer door of GE GSF25IGXNBB (Refrigerator & Freezer Repair)
by splinke 4 years ago
Freezer door opens fridge door every time (Refrigerator & Freezer Repair)
by coyote2 5 years ago
Ice dispenses when freezer door closes (Refrigerator & Freezer Repair)
by wrb 6 years ago
Fridge and Freezer door sag (Refrigerator & Freezer Repair)
by WLHuard 7 years ago
Bottom of freezer door sticks out (Refrigerator & Freezer Repair)
by smithd441@gmail.com 8 years ago
