Asko 7305 dryer was drying and then stopped working and won't turn on. Could be a blown fuse? No power light is coming on and since washing machine runs off the dryer, the washing machine won't turn on either.
Did you ever find out what the problem was with your Asko Dryer? I have a similar problem, although it doesn't affect the operation of the washer. However, I smell a burned odor in the dryer. The switch turns the power on, but the control panel is unresponsive and does not even register a problem code.
