The middle rail where the gaskets seal to is very hot almost too hot to touch. What could be causing this and how do I repair it.
Thanks Steve
Any response? I have the same issue
Reisc and Surato,
The first thing I would do is remove the rear cover and the front bottom grille and clean the condenser coil. Check if the fan next to the condenser is working properly.
