danjeep
#1 Posted : Monday, October 18, 2010 5:08:17 PM(UTC)
danjeep
dryer stoped heating need part easy to fix?
Joe / APP Team
#2 Posted : Tuesday, October 19, 2010 6:40:49 AM(UTC)
Joe / APP Team
Dan,
What have you done so far ?
Best quick guess, at this point would be a broken igniter, of there's no heat at all,
Second guess would be a bad set of valve coils, if it's an intermittent heat or noise during dry cycle.
Have you removed the front panel and observed the gas valve for operation ?
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
MAYTAG MVWB725BW0 ISSUE (Washer Repair)
by jim hull 6/24/2024 6:25:14 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Older Maytag won't run (Washer Repair)
by PatAMcD 6/6/2024 12:39:06 PM(UTC)
Maytag vibration after new suspension (Washer Repair)
by Poprox0013 6/5/2024 9:49:34 PM(UTC)
maytag maxima mhw6000aw0 (Washer Repair)
by Guest 5/28/2024 6:30:55 AM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Maytag DE313 Auto Dry malfunction (Dryer Repair)
by DeanEyford 5/5/2024 11:42:21 AM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytage PYE3300AYW: can't seat drum on new wheels (Dryer Repair)
by Guest 4/26/2024 3:05:06 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag Light (Dishwasher Repair)
by Rleblanc 4/22/2024 8:47:19 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
