dryer stoped heating need part easy to fix?
Originally Posted by: danjeep  dryer stoped heating need part easy to fix? Dan, What have you done so far ? Best quick guess, at this point would be a broken igniter, of there's no heat at all, Second guess would be a bad set of valve coils, if it's an intermittent heat or noise during dry cycle. Have you removed the front panel and observed the gas valve for operation ? :) :) :)
