ohiosparky
#1 Posted : Wednesday, October 13, 2010 1:41:28 PM(UTC)
ohiosparky
Hello, new to the site and have a question, we have a frigidaire professional,stainless steel, electric range. We purchased it new in april, 05. We have been getting an f10 error after we turn the oven on, just curious what it means and if we can fix it. I am an electrical contractor so i can use a meter if needed, so any help would be great. Thanks a lot
#2 Posted : Wednesday, October 13, 2010 5:19:41 PM(UTC)
The "F10" error code means that the control senses the runaway temperature.
Pull the range out of the wall and remove the rear panel. Measure the resistance of the temperature sensor (#37 on the diagram) and check its wiring harness. The normal resistance suppose to be about 1100 Ohms at the room temperature.
If the reading is incorrect, replace the temperature sensor.
If the reading is correct and the wiring is fine, replace the EOC. It is recommended by the manufacturer to replace the clock overlay together with the EOC.
- The temperature sensor Part number: AP3969435
Frigidaire Stove F10 Error (Oven Repair (including Ranges and Cooktops))
by ronusmc 1/4/2014 8:08:21 AM(UTC)
F10 error (Oven Repair (including Ranges and Cooktops))
by ciglady 9/9/2013 1:20:16 PM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
f10 error (Oven Repair (including Ranges and Cooktops))
by bizzybeez 7/23/2012 4:24:28 AM(UTC)
F10 error message random beeping (Oven Repair (including Ranges and Cooktops))
by favored 3/16/2012 9:27:24 AM(UTC)
Kenmore Electric Range - F10 Error (Oven Repair (including Ranges and Cooktops))
by blackwidow71 6/19/2011 3:02:24 PM(UTC)
Kenmore Range F10 error (Oven Repair (including Ranges and Cooktops))
by kaf27033 3/7/2011 12:17:32 PM(UTC)
F10 Error Code; Runaway Temperature (Oven Repair (including Ranges and Cooktops))
by Keith Hocky 10/18/2010 4:11:10 PM(UTC)
What does an F10 Error Code Mean? (Oven Repair (including Ranges and Cooktops))
by gwest2010 1/19/2010 6:38:10 AM(UTC)
f10 error code (Oven Repair (including Ranges and Cooktops))
by lindi 1/15/2008 9:54:51 AM(UTC)
