ciglady
#1 Posted : Monday, September 9, 2013 1:20:16 PM(UTC)
ciglady
How do I go about fixing this problem? What part # do I need to purchase?
Thank you
HumboldtRepairMan
#2 Posted : Monday, September 9, 2013 3:50:25 PM(UTC)
HumboldtRepairMan
It means you have a runaway temperature. Check the temp probe first it should ohm around 1100 ohms around room temperature. Then set it to 350 degrees and disconnected the temp probe and it should be around 16k ohms............If not it's a bad probe and if it does measure right then you have to replace the EOC and the plastic overlay which is the main control unit behind the touchpad. Here's your parts and a video on how to test the probe
Parts for Kenmore Range 79094002601 - AppliancePartsPros.com
testing oven temp probe - YouTube
Frigidaire Stove F10 Error (Oven Repair (including Ranges and Cooktops))
by ronusmc 1/4/2014 8:08:21 AM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
f10 error (Oven Repair (including Ranges and Cooktops))
by bizzybeez 7/23/2012 4:24:28 AM(UTC)
F10 error message random beeping (Oven Repair (including Ranges and Cooktops))
by favored 3/16/2012 9:27:24 AM(UTC)
Kenmore Electric Range - F10 Error (Oven Repair (including Ranges and Cooktops))
by blackwidow71 6/19/2011 3:02:24 PM(UTC)
Kenmore Range F10 error (Oven Repair (including Ranges and Cooktops))
by kaf27033 3/7/2011 12:17:32 PM(UTC)
F10 Error Code; Runaway Temperature (Oven Repair (including Ranges and Cooktops))
by Keith Hocky 10/18/2010 4:11:10 PM(UTC)
by ohiosparky 10/13/2010 1:41:28 PM(UTC)
What does an F10 Error Code Mean? (Oven Repair (including Ranges and Cooktops))
by gwest2010 1/19/2010 6:38:10 AM(UTC)
f10 error code (Oven Repair (including Ranges and Cooktops))
by lindi 1/15/2008 9:54:51 AM(UTC)
