How do I go about fixing this problem? What part # do I need to purchase? Thank you
It means you have a runaway temperature. Check the temp probe first it should ohm around 1100 ohms around room temperature. Then set it to 350 degrees and disconnected the temp probe and it should be around 16k ohms............If not it's a bad probe and if it does measure right then you have to replace the EOC and the plastic overlay which is the main control unit behind the touchpad. Here's your parts and a video on how to test the probe Parts for Kenmore Range 79094002601 - AppliancePartsPros.com testing oven temp probe - YouTube
