jcreek
#1 Posted : 17 years ago
jcreek
My washer will not spin or drain water,the switch under the lid seems to be ok the washer will fill with water but wont spin or drain, PLEASE HELP
misterfixall
#2 Posted : 17 years ago
misterfixall
does it agitate after it fills?
jcreek
#3 Posted : 17 years ago
jcreek
Yes It Agitates After It Fills.
misterfixall
#4 Posted : 17 years ago
misterfixall
usuall the problem is lid switch,try bypassing it
ritchisa
#5 Posted : 17 years ago
ritchisa
I am having the same problem, I can hear the motor trying to move (electrical hum) until I lift the lid and the hum returns when I close the lid, so I assume its not the switch.
misterfixall
#6 Posted : 17 years ago
misterfixall
if washer agitates +motor hums on drain +spin period .you may have motor problem
btkearney71@msn.com
#7 Posted : 17 years ago
btkearney71@msn.com
I Just Replaced The Timer On My Whirlpool Washer It Did Not
Solve The Problem What Else Could Be Wrong.
My Model Number Is Lsr 8133hqo.
jcreek
#8 Posted : 17 years ago
jcreek
Thanks for all of your post the washer will drain now but wont spin the motor is on but basket wont spin? And this shouldnt have a belt right?
scottthefixitguy
#9 Posted : 8 years ago
scottthefixitguy
Here's a quick lid switch cure:
https://youtu.be/wkySCkWCjtw
If you can hear the motor then it's the motor coupler or a bad clutch
Washer wont spin or drain (Washer Repair)
by steelem@myomnitel.com 11 years ago
washer wont spin or drain (Washer Repair)
by hunter02 12 years ago
by dionnaorner 12 years ago
Washer Wont Spin Or Drain (Washer Repair)
by tammy924 12 years ago
dishwasher wont spin or drain (Dishwasher Repair)
by jbenn 13 years ago
My washer wont spin or drain (Washer Repair)
by Elizabeth2323 13 years ago
roper washer wont spin or drain water (Washer Repair)
by michalek 14 years ago
by rday 15 years ago
