jcreek
#1 Posted : Tuesday, July 22, 2008 8:00:15 AM(UTC)
jcreek
My washer will not spin or drain water,the switch under the lid seems to be ok the washer will fill with water but wont spin or drain, PLEASE HELP
misterfixall
#2 Posted : Tuesday, July 22, 2008 3:27:31 PM(UTC)
misterfixall
does it agitate after it fills?
jcreek
#3 Posted : Wednesday, July 23, 2008 2:44:22 AM(UTC)
jcreek
Yes It Agitates After It Fills.
misterfixall
#4 Posted : Wednesday, July 23, 2008 9:29:44 AM(UTC)
misterfixall
usuall the problem is lid switch,try bypassing it
ritchisa
#5 Posted : Wednesday, July 23, 2008 12:28:45 PM(UTC)
ritchisa
I am having the same problem, I can hear the motor trying to move (electrical hum) until I lift the lid and the hum returns when I close the lid, so I assume its not the switch.
misterfixall
#6 Posted : Wednesday, July 23, 2008 1:53:53 PM(UTC)
misterfixall
if washer agitates +motor hums on drain +spin period .you may have motor problem
btkearney71@msn.com
#7 Posted : Wednesday, July 23, 2008 5:14:59 PM(UTC)
btkearney71@msn.com
I Just Replaced The Timer On My Whirlpool Washer It Did Not
Solve The Problem What Else Could Be Wrong.
My Model Number Is Lsr 8133hqo.
jcreek
#8 Posted : Saturday, July 26, 2008 12:49:20 PM(UTC)
jcreek
Thanks for all of your post the washer will drain now but wont spin the motor is on but basket wont spin? And this shouldnt have a belt right?
scottthefixitguy
#9 Posted : Saturday, April 8, 2017 8:00:51 PM(UTC)
scottthefixitguy
Here's a quick lid switch cure:
https://youtu.be/wkySCkWCjtw
If you can hear the motor then it's the motor coupler or a bad clutch
Guest (6)
Washer wont spin or drain (Washer Repair)
by steelem@myomnitel.com 2/3/2014 10:20:19 AM(UTC)
washer wont spin or drain (Washer Repair)
by hunter02 7/15/2013 10:36:02 PM(UTC)
by dionnaorner 4/11/2013 5:27:51 PM(UTC)
Washer Wont Spin Or Drain (Washer Repair)
by tammy924 1/17/2013 10:11:49 AM(UTC)
dishwasher wont spin or drain (Dishwasher Repair)
by jbenn 6/4/2012 7:12:32 PM(UTC)
My washer wont spin or drain (Washer Repair)
by Elizabeth2323 4/5/2012 5:15:32 PM(UTC)
roper washer wont spin or drain water (Washer Repair)
by michalek 3/28/2011 6:59:22 PM(UTC)
by rday 11/1/2009 7:07:27 PM(UTC)
