the dishwasher will fill with water, but the washer arm will not spin. and it will not drain either. The control dial will go from start to finish. But the only thing it does is fill with water.
Groups: APP Team
Hi.
Do you hear the motor running?
Simon.
Simon. hi simon no the motor does not run
Remove the toe panel and check if the motor humming during the wash cycle. If it's humming, replace the pump & motor assembly. If it's not, remove the wire plug from the motor and check for 120 VAC between the wires while the dishwasher is on wash cycle. Post the results. - The pump and motor assembly Part number: W10247394
i checked and it had power coming to it. I replaced the motor and pump it works fine now . Thank You John
You are welcome John. We are glad it's up and running.
