jbenn
#1 Posted : Monday, June 4, 2012 7:12:32 PM(UTC)
jbenn
the dishwasher will fill with water, but the washer arm will not spin. and it will not drain either. The control dial will go from start to finish. But the only thing it does is fill with water.
Simon / APP Team
#2 Posted : Tuesday, June 5, 2012 10:19:30 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Do you hear the motor running?
Simon.
jbenn
#3 Posted : Tuesday, June 5, 2012 6:45:25 PM(UTC)
jbenn
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
hi simon no the motor does not run
#4 Posted : Wednesday, June 6, 2012 12:45:46 PM(UTC)
Remove the toe panel and check if the motor humming during the wash cycle.
If it's humming, replace the pump & motor assembly.
If it's not, remove the wire plug from the motor and check for 120 VAC between the wires while the dishwasher is on wash cycle. Post the results.
- The pump and motor assembly Part number: W10247394
jbenn
#5 Posted : Friday, June 8, 2012 3:45:48 PM(UTC)
jbenn
i checked and it had power coming to it. I replaced the motor and pump it works fine now . Thank You John
#6 Posted : Friday, June 8, 2012 4:23:55 PM(UTC)
You are welcome John. We are glad it's up and running.
Guest (7)
