spass
#1 Posted : Tuesday, September 21, 2010 7:01:11 AM(UTC)
spass
On the inside left door is a water dispenser, I need the valve number that should be located behind this button, it is leaking.
Thank you
Joe / APP Team
#2 Posted : Tuesday, September 21, 2010 7:54:03 AM(UTC)
Joe / APP Team
Thank you
Spass,
There is no valve located behind the switch assembly for your water dispenser.
Only a switch and the water tube.
If you need a valve, it is located on the back of the refrigerator.
A couple of questions first .
How are the ice cubes from the ice maker ?
Full sized, solid cubes ?
Have you replaced the water filter in your system ?
Did you recently disconnect or shut off the water supply to the refrigerator ?
If or once you've checked all of these, and flushed the water dispenser (dispense 2 qts. of water to flush the system).
Here are some parts you may want to consider replacing :
Part number: AP4080917
Part number: AP4366606
Part number: AP4078344
And some instructions for the dispenser removal.
Water Dispenser (some models)
1. Turn water off to unit.
2. Remove crispers from fresh food compartment.
3. Carefully pry top cover of dispenser out and remove.
4. Remove hex head screw to release dispenser from
cabinet.
5. Disconnect compression nut from union at outlet of
tank.
6. Remove compression nut from tubing.
7. Pull dispenser assembly and tube out of side wall.
8. Reverse procedure to reassemble
Good Luck,
spass
#3 Posted : Tuesday, September 21, 2010 8:07:53 AM(UTC)
spass
I need the switch
Joe / APP Team
#4 Posted : Tuesday, September 21, 2010 10:34:00 AM(UTC)
Joe / APP Team
Thank you
Spass,
OK, Does the dispenser not work ?
Or not shut off ?
Maybe I mis understood you.
Part number: AP4014761
spass
#5 Posted : Tuesday, September 21, 2010 10:39:20 AM(UTC)
spass
It will leak but not all the time,
Joe / APP Team
#6 Posted : Tuesday, September 21, 2010 11:01:25 AM(UTC)
Joe / APP Team
Spass,
It might be best that you do replace the switch, as well.
I haven't run into that particular scenario, myself, but it is a good possibility.
Good Luck,
:cool: :cool: :cool:
spass
#7 Posted : Tuesday, September 21, 2010 7:05:19 PM(UTC)
spass
Can you give me the part numbers so I can order
Joe / APP Team
#8 Posted : Wednesday, September 22, 2010 5:05:53 AM(UTC)
Joe / APP Team
Spass,
I had attached it to my previous post.
Part number is,
AP4014761 Labelled limit switch.
spass
#9 Posted : Wednesday, September 22, 2010 2:20:37 PM(UTC)
spass
I need part number please, thank you
Joe / APP Team
#10 Posted : Thursday, September 23, 2010 5:07:17 AM(UTC)
Joe / APP Team
Spass,
Here is the part Number,
AGAIN .
(click on number for part information)
:confused: :confused: :confused:
Ice and water dispenser beeps only (Refrigerator & Freezer Repair)
by Guest 5/31/2024 7:53:16 AM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
water dispenser sporadically dispenses water (Refrigerator & Freezer Repair)
by ddxxoo 3/20/2024 2:55:42 PM(UTC)
Water dispenser not working GE Profile PSHs6TGXBDS (Refrigerator & Freezer Repair)
by klkaylor78 2/3/2024 11:07:08 AM(UTC)
GE fridge water dispenser slows to trickle, speeds up when filter is twisted (Refrigerator & Freezer Repair)
by Guest 1/11/2024 5:03:35 AM(UTC)
water dispenser stopped working. No light no pwer (Refrigerator & Freezer Repair)
by waterdispprob 11/19/2023 10:08:39 AM(UTC)
Frigidaire Gallery ice maker sending water to water dispenser?? (Refrigerator & Freezer Repair)
by jonny comfort 6/11/2023 7:49:11 PM(UTC)
Frigidaire Refrigerator Ice Maker and Water Dispenser not working (Refrigerator & Freezer Repair)
by kehoetj 5/9/2023 3:57:44 PM(UTC)
Kenmore Coldspot model 106.9555611 Water Dispenser (Refrigerator & Freezer Repair)
by reynolpe 2/14/2023 1:40:10 PM(UTC)
LG Fridge - Water Dispenser barely flowing (Refrigerator & Freezer Repair)
by AZ_Desert 1/28/2023 7:03:14 AM(UTC)
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Whirlpool Refrigerator inside lights, ice and water dispenser doesn't work (Refrigerator & Freezer Repair)
by Guest 1/6/2023 5:15:20 PM(UTC)
electrolux fridge Water dispenser doesn’t work (Refrigerator & Freezer Repair)
by max57 10/28/2022 2:33:45 PM(UTC)
Electrolux Refrigerator Water Dispenser Sticks Open (Refrigerator & Freezer Repair)
by Thom64 7/30/2022 8:42:45 AM(UTC)
