my oven doesn't light, oven goes thru its count down and clicks about 5 times, then i half to try again. my son said he see a wire in the back that look like the cover is ripped and some copper wire are broken. What is this wire my son talking about.
Originally Posted by: rodebob ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) my oven doesn't light, oven goes thru its count down and clicks about 5 times, then i half to try again. my son said he see a wire in the back that look like the cover is ripped and some copper wire are broken. What is this wire my son talking about. It could be the bake burner igniter, and may be normal, Part number: AP3594295
You said you could hear 5 clicks, did you watch the igniter to see if it sparked and lit the burner ? Is the gas on to the machine ? Is the burner tube itself, clean and are the burner ports clogged ? Does the broil burner operate proper ? Do the top burners work ? We'll have a better idea of which way to go, once we get your response. Thanks, :) :) :)
The top burner does light. The gas is on. Broiler does work. the igniter lights some times after about 15 minutes trying and some times it doesn't. the burner tube is clean and it is not clogged.
Gas Is On, Tube Is Clean And Not Plugged. Broiler Works
Originally Posted by: rodebob ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) my oven doesn't light, oven goes thru its count down and clicks about 5 times, then i half to try again. my son said he see a wire in the back that look like the cover is ripped and some copper wire are broken. What is this wire my son talking about. Rodebob, OK, Something you may want to try, On the burner tube, the ignition venturi holes(the ones that go across the bottom of the tube) if you're sure they are all clean and not clogged, you may want to increase the openings by 1 drill size. Check the wire to the igniter for loose connections and make sure you've got a good ground to the unit. If everything is proper, or you continue to have a problem, Replace the Spark Module control board. Part number: AP3672576
Good Luck, :cool: :cool: :cool:
thanks for coming our site: nike,nike shoes,jordan shoes-www.nikeok.com , best quality and customer service here!be pleased to inform you,we just updated our site products online, and now you can place order and get a good deal with discount price online, below some changes for your informations;1. all items with reasonable prices, and easy to order.2, if you order over 120usd, all items will be free shipping.3, for above 200usd order, we hv a special gifts for every packages.our shipping service as following;a. payment: Paypal/western union/money gramb. shipping way: EMS,USPS,DHLc. shipping time: about 3-5daysd. deliver model: door deliveryyou can place order online, we will get your order details when you finish order online,thanks for your time!all the bestqingcustomer service rep. nike,nike shoes,jordan shoes-www.nikeok.com
