candrews922
#1 Posted : Monday, June 22, 2009 7:37:03 AM(UTC)
candrews922
Our oven wouldn't light a number of weeks ago. It would release gas and you could hear the spark repeating and igniting the burner. It kept doing this on and off, and some heat could be felt, so it had to have lit. About a week later we tried to use the oven and it worked fine. It is now doing the same thing again. I would like to try cleaning the parts involved with this process, before more aggressive troubleshooting, can you help me?:confused:
candrews922
#2 Posted : Tuesday, June 23, 2009 10:08:00 AM(UTC)
candrews922
Okay, if anyone read this and wants to help. I checked the igniter and burner. The wires on the igniter looked like a mouse had chewed off the insulation. I covered the wire, and cleaned the inside area, and the holes on the burner. Before taking the igniter out, I had tried to lite the oven, the igniter clicked and arced but the burner did not lite. After what I did ,the burner lit, but the flame went out after around 10 to 15 seconds. It would attempt to relight after another pause. All other stove parts are working. Any suggestions? My model number is off by a digit and I have a bad back and it is hard for me to get to it's location. Thanks.
whirlpool wfg510s0ab2 oven not lighting (Oven Repair (including Ranges and Cooktops))
by sparktender 1/15/2024 1:43:04 PM(UTC)
GE Double Gas Upper Oven not lighting (Oven Repair (including Ranges and Cooktops))
by Richard Leatherwood 11/6/2019 6:18:52 PM(UTC)
Oven not lighting and now an RTD short code. (Oven Repair (including Ranges and Cooktops))
by Michaeljaymes 12/20/2016 7:40:15 AM(UTC)
DCS Oven not lighting (Oven Repair (including Ranges and Cooktops))
by yeldogt 9/13/2016 3:39:24 AM(UTC)
DCS SC305 Range -Oven Not lighting (Oven Repair (including Ranges and Cooktops))
by crmichaels 11/13/2013 6:13:11 AM(UTC)
Gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by Fred Enright 9/24/2013 10:02:10 PM(UTC)
by ricky1842 12/20/2012 6:55:09 AM(UTC)
Kenmore gas oven not lighting (Oven Repair (including Ranges and Cooktops))
by wingmaster12 11/11/2012 11:11:11 AM(UTC)
Ge XL44 smell of gas, oven not lighting up quickly (Oven Repair (including Ranges and Cooktops))
by MKrieck 7/22/2012 6:40:21 PM(UTC)
Oven not lighting but ignitor lit ? (Oven Repair (including Ranges and Cooktops))
by t4beatles 7/16/2011 6:40:33 AM(UTC)
by rodebob 9/21/2010 4:28:45 AM(UTC)
OVEN not lighting??? (Oven Repair (including Ranges and Cooktops))
by DANICA1985 8/12/2010 9:59:20 AM(UTC)
PLEASE? Frigidaire Gas Oven Not Lighting? (Oven Repair (including Ranges and Cooktops))
by mikk 4/8/2010 11:02:11 AM(UTC)
oven not lighting up. (Oven Repair (including Ranges and Cooktops))
by barney 12/19/2008 5:20:04 AM(UTC)
Oven not lighting after gas turned off then on (Oven Repair (including Ranges and Cooktops))
by nbrock51 11/10/2008 7:39:31 AM(UTC)
