Don Empey
#1 Posted : Saturday, September 11, 2010 7:31:28 AM(UTC)
Don Empey
Pulled trap & removed coins & bobbie pins, Pump drains but won't spin
sidfink43
#2 Posted : Monday, September 13, 2010 9:23:11 AM(UTC)
sidfink43
The weak link in these machines is the speed control board, but it is an expensive part so use this service manual to troubleshoot it before replacing that board.
http://frigidaireservicetips.co...AffinityWasherManual.pdf
Don Empey
#3 Posted : Tuesday, September 14, 2010 6:56:59 PM(UTC)
Don Empey
This problem happened a year ago, the tech replaced the door lock. I picked 1 up, installed it last weekend & the problem went away. I opened up (unsnapped the old switch) & found the aux contacts got misaligned, thus causing a E47 Door Open code. A little glue can keep the contacts secure & prevent another costly service call. I also down loaded the service guide for $15.00, a must for servicing & troubleshooting.
Helps to be an HVAC tech, thanks for getting back to me, Don
sidfink43
#4 Posted : Wednesday, September 15, 2010 4:13:06 AM(UTC)
sidfink43
Great, glad you were able find the problem. The door lock mechanism is the other weak point on these machines.
Thanks for the update, good luck with your washer going forward.
WPSR3100W1WW - Clothes too wet after spin cycle? (Washer Repair)
by Countryhome 5/2/2024 12:58:04 PM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
GE WBSR3140DAWW Does not spin during rinse/spin cycle (Washer Repair)
by nj_999 12/23/2023 3:31:43 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Maytag Maxima front load washer hangs on spin cycle (Washer Repair)
by jcross100 8/6/2023 11:56:11 AM(UTC)
MVWC7ESWW0 - jumps to spin cycle (Washer Repair)
by Guest 7/15/2023 10:08:10 AM(UTC)
Washer banging sides and walks all over when spin cycle (Washer Repair)
by Guest 6/29/2023 6:24:43 PM(UTC)
Kenmore Washer bounces around on spin cycle (Washer Repair)
by JerryCaldwell 6/1/2023 12:44:27 PM(UTC)
Excessive vibration during spin cycle (Dishwasher Repair)
by JerryCaldwell 5/14/2023 9:36:02 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Whirlpool, grinding badly at end of spin cycle (Washer Repair)
by cdestuck 2/6/2023 10:54:05 AM(UTC)
whirlpool lsc8244bq0 agitates during rince and spin cycle (Washer Repair)
by Guest 1/31/2023 12:30:04 PM(UTC)
Loud noise at start of spin cycle that stops once at high RPM (Washer Repair)
by tollisal 1/28/2023 8:48:50 AM(UTC)
washer fills with water at spin cycle (Washer Repair)
by Guest 1/26/2023 1:13:27 PM(UTC)
