smg60
#1 Posted : Monday, July 14, 2008 2:18:09 PM(UTC)
smg60
I have a gas oven with an electronic igniter. When you set the oven temp., it goes through a timeout process to preheat the oven. The oven would usually light after 1 or 2 arcs from the igniter, but as of late even if it lights, the igniter will continue to arc 3 or 4 more times like it is trying to light and then the oven will shut off. This occurs throughout the 10 or 15 min. timeout process. When the oven preheat process finishes you can turn it off and reset the oven temp. and it will usually light and stay lit and come up to temp. and cycle normally. What gives? Is it a bad igniter or spark controler or what? It gets aggrivating having to start the oven twice everytime.
#2 Posted : Tuesday, July 15, 2008 3:18:05 PM(UTC)
Most likely the cause of intermittent ignition is poor performance of the bake burner and/or igniter. In order to correct this problem Whirlpool designed new improved burner/igniter kit which should be installed in your oven.
- The part number for the bake burner/igniter kit is AP3598752
1960's Oven Repair - Need model # (Oven Repair (including Ranges and Cooktops))
by jarla 12/13/2020 10:48:51 AM(UTC)
GE oven repair (Oven Repair (including Ranges and Cooktops))
by arshlo 12/10/2016 7:51:10 AM(UTC)
Oven Repair (Oven Repair (including Ranges and Cooktops))
by ridenroaddog 12/9/2013 11:06:59 AM(UTC)
by ANTHONYMAYWEATHERS 8/5/2013 4:45:40 PM(UTC)
by miguel 2 4/14/2013 10:06:22 AM(UTC)
Frigidaire Oven Repair Problem (Oven Repair (including Ranges and Cooktops))
by PetraMarion 2/25/2013 4:58:33 AM(UTC)
by johnthrasher45 2/9/2013 12:04:31 PM(UTC)
by johnthrasher45 2/8/2013 10:04:38 AM(UTC)
Oven repair (Oven Repair (including Ranges and Cooktops))
by johnthrasher45 2/8/2013 3:57:12 AM(UTC)
by johnthrasher45 2/7/2013 11:59:12 AM(UTC)
Questioning my first Oven Repair (Oven Repair (including Ranges and Cooktops))
by morbe 1/4/2013 1:18:05 PM(UTC)
by artalba 12/16/2012 5:07:10 PM(UTC)
GE Oven Repair Question? (Oven Repair (including Ranges and Cooktops))
by ejprap 11/7/2012 4:30:59 AM(UTC)
by gettone 10/23/2012 6:08:08 AM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
