Sunshineoeff
#1 Posted : Wednesday, September 8, 2010 7:03:58 AM(UTC)
Sunshineoeff
I have been reading the post and I think my defrost system is bad. There is ice on the evap coil but I can't find a defrost time or board. What controls the defrost cycling. Thanks
#2 Posted : Friday, September 10, 2010 5:17:48 AM(UTC)
Replacement parts for WHIRLPOOL GX5FHDXTQ00 Refrigerator | AppliancePartsPros.com
Here is the tech sheet. Note: It is for a Q01 which is the closest I could find for your unit.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%2012827952.pdf
Control board is Item 5 in Section 3 of the parts.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, around 30 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Freezer cold, Fridge Warm Kenmore 253.60082411. Model doesn't have timer (Refrigerator & Freezer Repair)
by jhmon 5/29/2020 12:20:04 AM(UTC)
Freezer cold, fridge warm Whirlpool (Refrigerator & Freezer Repair)
by Debma 1/25/2016 11:09:49 PM(UTC)
Freezer cold, Fridge warm (Refrigerator & Freezer Repair)
by mburke615 4/15/2013 11:39:06 AM(UTC)
freezer cold, fridge warm, damper closed tite (Refrigerator & Freezer Repair)
by thecac 7/11/2012 11:25:55 AM(UTC)
Freezer cold, fridge warm (Refrigerator & Freezer Repair)
by spartom 7/3/2012 5:11:47 PM(UTC)
GE freezer cold, fridge warm (Refrigerator & Freezer Repair)
by dsandwich 7/1/2012 1:21:45 PM(UTC)
Freezer cold, fridge warm, unit constantly running (Refrigerator & Freezer Repair)
by mista_eng 5/30/2011 8:14:22 PM(UTC)
Freezer cold, fridge warm - please help !! (Refrigerator & Freezer Repair)
by aviator2010 9/25/2009 10:02:45 AM(UTC)
