Looking for reason food is freezing in the refrigerator compartment. On occasion the water to the dispenser also freezes and the filter is frozen solid. Some of searches indicate flapper or thermistor but I can't seem to locate as have no diagram to look at.
Thanks, Mark
Sorry that link wont work. Go to www.geappliances.com, go to parts. Enter you model# and you will get an exploded view of your refer. Go to freshfood section, and there you will see where the damper is located.
Thanks, but I don't see a item #426. See #459. Also, any guidance on getting to the part in the refrigerator? Thanks again.
