Bill123
#1 Posted : Thursday, September 2, 2010 12:21:19 PM(UTC)
Bill123
My dryer stoppped heating, realling breaking me heart since I paid 2K for both washer and dryer??? I know it seems old but any help troubleshooting woudl be greatlt appreciated!!!NO Heat at all!!! I have been using the local laundromat, but woudl like to fix this before I call someone. Heard this was a great resource, hoping someone out there has a few suggestions???
:eek:
#2 Posted : Thursday, September 2, 2010 3:37:14 PM(UTC)
Hi Bill,
You have to have a simple meter to perform the troubleshooting. You may want to start with checking the voltage at the dryer wall outlet. The normal readings suppose to be: 120 VAC between each hot wire and the neutral and 240 VAC between the hot wires. If one of the "legs" is missing, the motor would still run while the heating element needs 240 VAC. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEW9250PW0 Electric Dryer | AppliancePartsPros.com
Here is the Tech sheet.
Bill123
#3 Posted : Saturday, September 4, 2010 3:53:08 PM(UTC)
Bill123
Hi Bill,
Gene, Thnks for the info. I plan to check it all tomorrow, (Before football)!!!! I will definitely post my findings, appreciate the response.....
noots566
#4 Posted : Saturday, September 4, 2010 6:49:27 PM(UTC)
noots566
have no heat but still runs check wall outlit and its 240 heating elements are not turning red is it my thermostat or heating elements need replaced
#5 Posted : Monday, September 6, 2010 1:55:41 PM(UTC)
What is the complete model number of the dryer?
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
