capndavid2001
#1 Posted : Tuesday, August 31, 2010 6:08:08 AM(UTC)
capndavid2001
I pulled my dishwasher from under the counter to clean behind it. Since then the dishwasher has no indication of power on the control panel. I checked the fuse on the door panel, appears ok with a meter, the latch mechanism works, passes 120v when closed. What am I missing? Is there another fuse or switch somewhere on the unit which may be tripped? Is there another location I can go to pin the problem down? Thank you.
#2 Posted : Wednesday, September 1, 2010 2:04:34 AM(UTC)
Could not find JDL0, following is for a TJBL0
Here are the parts
Replacement parts for WHIRLPOOL KUDR01TJBL0 Undercounter Dishwasher | AppliancePartsPros.com
Perhaps the following will help you troubleshoot
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208269519.pdf
Check Item 6 in Section 2.
capndavid2001
#3 Posted : Wednesday, September 1, 2010 5:01:43 AM(UTC)
capndavid2001
Thank you Denman, I found the links you provided and used the electrical schematic to troubleshoot the washer. I was able to troubleshoot the circuit board to discover the switch gate power supply was working and the rest of the control system seemed to be intact and functioning. The only thing I discovered was the ribbon cable connecting the circuit board to the touch panel had several burn spots. I believe this is why none of the touch pads work and no lights to indicate status. I hope I can replace the ribbon cable and not the entire touch panel. Pretty pricy. I did not see a ribbon cable on the parts link you provided.
#4 Posted : Wednesday, September 1, 2010 7:05:37 AM(UTC)
The ribbon cable is not available as a separate item.
Possible dryer electrical problem (Dryer Repair)
by Dmillbhawk 8/1/2013 10:43:43 AM(UTC)
Do I have electrical problem? Soap dispenser? (Dishwasher Repair)
by roger20 3/13/2012 3:42:47 PM(UTC)
electrical problem (Oven Repair (including Ranges and Cooktops))
by robertwgeorge 2/9/2012 6:44:19 PM(UTC)
electrical problem (Washer Repair)
by garycart 4/4/2011 4:57:29 PM(UTC)
Maytag Dryer - first noise, now also electrical problem (Dryer Repair)
by RobBroekhuis 11/7/2009 2:23:58 PM(UTC)
Electrical problem (Washer Repair)
by hb6306 9/10/2009 12:55:10 PM(UTC)
Icemaker front panel electrical problem (Refrigerator & Freezer Repair)
by ttvor 6/20/2009 2:10:55 PM(UTC)
Electrical Problem (Garbage Disposer Repair)
by Debra Carlin 11/15/2008 6:04:36 PM(UTC)
Electrical problem (Refrigerator & Freezer Repair)
by mcbdallas 2/19/2008 11:27:42 AM(UTC)
