brantd
#1 Posted : Friday, August 27, 2010 10:18:16 AM(UTC)
brantd
not sure of the age.
long story, but bottom line is my son has a double oven I'm trying to now fix which he had wired the plug wrong and plugged it in. Loud pop and smoke came out of oven, then left it pluged in for a couple min. He was told by the landlord the oven worked fine before (not that he REALLY knows for sure)
First, I do have power going to the oven. I have replaced the suppressor (which looked VERY burnt), then the microcomputer board. I have checked the Thermal fuse connected to the micro board and it is ok. Still no power on display......what should I try next?
I do have an ohmmeter, but been a while sense I have used (played) with it.
#2 Posted : Friday, August 27, 2010 10:45:50 AM(UTC)
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%204451879.pdf
When you say you have power to the unit did you check for the 240 and also the 120 on each leg. You need 120 volts from Neutral to L1 for the control board power transformer.
Remove power from the unit and check the transformer windings for continuity.
Remember to disconnect at least one side of each winding when checking just to be sure you do not read an alternate/parallel circuit path.
I do not know what they should be other than they should not be an open.
If both the primary and secondary have continuity you will have to do a live test.
I would do this the first time with the control board disconnected.
Tech sheet says the secondary should put out 20.3 volts approx.
If OK check it again with the control board hooked up just to see if the control board is dropping it for some reason.
brantd
#3 Posted : Friday, August 27, 2010 11:52:28 AM(UTC)
brantd
Primary (two red wires) is open and the secondary (two small blue wires) is closed
Sounds like a need a power transformer?
#4 Posted : Friday, August 27, 2010 1:44:40 PM(UTC)
[COLOR="Blue"]Sounds like a need a power transformer?[/COLOR]
Yes that is what I would also conclude
brantd
#5 Posted : Friday, August 27, 2010 1:58:54 PM(UTC)
brantd
ordered, will be here tomorrow, I'll keep you posted
brantd
#6 Posted : Monday, August 30, 2010 1:06:43 PM(UTC)
brantd
replaced parts, oven now turns on.
some buttons work on key pad, some don't. I can't set the clock, upper and lower oven buttons don't work, cancel don't work. However I can turn oven on to broil, convection, stet time to start, and a few others.
I cleaned the connection ribbon, didn't help.....so I now need some help from you! :)
My GUESS is it needs a new touch pad, but you seem to be out of stock. If you think that is what I need, how soon can I get one?
PS Sorry I couldn't find this thread at first and post it to a new thread...please ignore
GE Trutemp wall oven won't turn on (Oven Repair (including Ranges and Cooktops))
by Jim West Pa 4/3/2021 10:08:00 AM(UTC)
Oven won't turn ON on Bake setting (Oven Repair (including Ranges and Cooktops))
by hellotoall 6/22/2017 5:02:33 AM(UTC)
Oven won't turn on (Oven Repair (including Ranges and Cooktops))
by Viking85 12/18/2016 12:08:14 PM(UTC)
oven won't turn on bake (Oven Repair (including Ranges and Cooktops))
by crazyjohnny 1/8/2016 3:40:17 PM(UTC)
Maytag MERH865 oven won't turn on (Oven Repair (including Ranges and Cooktops))
by nmech123 8/17/2014 8:46:50 AM(UTC)
Oven won't turn on until knob is turned to really high temperature (Oven Repair (including Ranges and Cooktops))
by absoluteze 12/16/2013 8:24:07 AM(UTC)
by Elle Dee 5/8/2013 8:14:42 AM(UTC)
Magic Chef gas oven won't turn on (Oven Repair (including Ranges and Cooktops))
by giantfns 12/23/2012 3:09:30 PM(UTC)
Monogram Oven Won't Turn On/Respond (Oven Repair (including Ranges and Cooktops))
by dcmcewen 7/9/2012 5:06:31 PM(UTC)
Help! Lost power & now my Thermador PGR366ZS oven won't turn on (Oven Repair (including Ranges and Cooktops))
by chocomom 5/7/2012 7:57:59 AM(UTC)
G.E. Oven won't turn on (Oven Repair (including Ranges and Cooktops))
by wannafixit 10/7/2011 9:40:53 AM(UTC)
by Hometown1 5/25/2011 2:30:35 PM(UTC)
Oven won't turn on unless stove is on (Oven Repair (including Ranges and Cooktops))
by chrisp0455 11/23/2010 7:12:06 PM(UTC)
whirlpool oven code F3 63 oven won't turn on (Oven Repair (including Ranges and Cooktops))
by lkaymen 9/24/2010 4:57:03 AM(UTC)
GE Wall Oven won't turn on (Oven Repair (including Ranges and Cooktops))
by apachesurfer 8/31/2010 4:35:54 AM(UTC)
