Rank:: Member
My fridge keeps on clicking and doesn't turn on. Sometimes it turns on but mostly it just keeps on clicking. Sometimes when we move the temperature knob around it turns on. First the water and ice dispenser stopped working and then it started clicking. The fridge is only 1 1/2 years old. Does it need a new part? Please help!
Hi Sunny.
The clicking is the compressor relay on the main board located on the back of the back wall. To get to it, pull the unit out from wall, and behind the access panel on the lower right side is the main board. You will need a new board. I'm assuming that when you press the actuator pad to get ice or water that the panel lights dim and you get no water or ice?
