rajlovermaster
#1 Posted : Wednesday, August 30, 2017 9:50:18 AM(UTC)
rajlovermaster
I am having weird problem. My freezer and fridge stopped working on saturday...both the sections were warm... .... On Sunday i ordered 3 in 1 Starter kit to test and last night i installed it and the fridge started cooling again. The starting device that i took out was burnt but capacitor looked good.
The problem now is whenever i open the fridge side (right), the compressor goes off and it starts making clicking noise.....when i close the door it starts again... I was going to order OEM starting device and put it...will it fix it ??
below is video of the problem
https://www.youtube.com/watch?v=K5o4bsQ2Q7U&t=0s
dthayer
#2 Posted : Sunday, September 30, 2018 8:52:09 AM(UTC)
dthayer
Did you ever resolve this problem? I have the same fridge with the exact same problem... and it is getting worse! We are about to move and I'm trying to decide if it is worth taking... TIA
ohm
#3 Posted : Sunday, September 30, 2018 11:58:36 AM(UTC)
ohm
Was thanked: 3 time(s) in 3 post(s)
Use the OEM part and you may have a chance.Those 3& 1 kits should never be used on refrigerator with electronics.
Part number: WP2319792
Also run capacitors only makes the refrigerator a little more efficient and can run without it as long as the compressor is good so don't buy that and use the old one.Run Caps very seldom go bad.Here is your tech sheet.And parts List.
File Attachment(s):
GS5SHAXNB00 Wiring Sheet - 2255955.pdf (700kb) downloaded 0 time(s).
Repair Part List - 8198939 - Rev A.pdf (1,562kb) downloaded 0 time(s).
You cannot view/download attachments. Try to login or register.
