ghh3rd
#1 Posted : Thursday, August 26, 2010 12:39:09 PM(UTC)
ghh3rd
Maytag dryer Model LDE7600ACl runs and heats OK but makes loud noise like a small jackhammer. Removed cover and sound *seems* to be more on LH side.
Thanks for any tips.
Randy
Joe / APP Team
#2 Posted : Thursday, August 26, 2010 1:41:29 PM(UTC)
Joe / APP Team
Randy
Randy,
There are several things to check,
Remove the front tumbler support and check for something in the blower wheel, also check for a loose rounded out blower hub(those 2 are the most likely, based on your description).
Remove the belt and drum, check for a loose motor pulley,
and check the rear rollers for missing rubber on the surface that contacts the drum(least likeliest).
Part number: AP4294048
Part number: AP4373088
Part number: AP4008534
I'm sure you'll find your noise in one of these areas, and will be up and running soon.
ghh3rd
#3 Posted : Thursday, August 26, 2010 2:28:25 PM(UTC)
ghh3rd
Thanks a lot Joe! That gives me a good start.
Joe / APP Team
#4 Posted : Friday, August 27, 2010 5:33:56 AM(UTC)
Joe / APP Team
You're quite welcome,
Drop us a line when you're done with the repair.
