Maytag dryer Model LDE7600ACl runs and heats OK but makes loud noise like a small jackhammer. Removed cover and sound *seems* to be more on LH side.
Thanks for any tips.
Randy
Originally Posted by: ghh3rd  Maytag dryer Model LDE7600ACl runs and heats OK but makes loud noise like a small jackhammer. Removed cover and sound *seems* to be more on LH side.
Randy Randy, There are several things to check, Remove the front tumbler support and check for something in the blower wheel, also check for a loose rounded out blower hub(those 2 are the most likely, based on your description). Remove the belt and drum, check for a loose motor pulley, and check the rear rollers for missing rubber on the surface that contacts the drum(least likeliest). Part number: AP4294048
Thanks a lot Joe! That gives me a good start.
Originally Posted by: ghh3rd  Thanks a lot Joe! That gives me a good start. You're quite welcome, Drop us a line when you're done with the repair. :) :) :)
