Dave S
#1 Posted : Thursday, August 26, 2010 9:28:15 AM(UTC)
Dave S
Opening the door to the microwave blows fuses frequently. Under the cover, there is a notice to check the interlock and interlock monitor if it is blowing fuses.
Would replaceing the two door electronic sensors remedy this?
It is a stacked unit with the oven, so would like to fix if possible. all other functions work properly.
Dave
Joe / APP Team
#2 Posted : Thursday, August 26, 2010 10:55:27 AM(UTC)
Joe / APP Team
Dave
Dave,
I don't really think you need switches,
besides one of the switches you would need is no longer available.
If the switches were bad, your problem would be constant, not intermittent.
Were it me, I would attempt to realign the door switch mounting assembly.
and check the latch hook assembly on the door.
A) You may even want to remove the assembly and clean the mini plungers on all the switches.
B) I used to use "star washers", when remounting the switch assembly,
they help to hold the assembly screws tighter and grip the plastic housing and holds the mounting bracket in place longer.(you can get the washers at any local hardware store).
Apparently, you've been inside the control panel assembly, at least,and are aware of the possible shock hazard(s) when working in that area.
Good Luck,
