Jeffer
#1 Posted : Monday, August 23, 2010 10:12:25 AM(UTC)
Jeffer
Stopped cooling, I upluged it for 24 hours then I pluged it back in worked fine for a few days then stopped cooling again. was told it could be a defrost timer. I looked up parts diagram online did not see a defrost timer listed. there was 2 different defrost therastats. could one of these be the problem.
#2 Posted : Monday, August 23, 2010 12:24:44 PM(UTC)
Have you seen a frost build up on the rear panel inside the freezer?
Does the fan inside the freezer work properly?
Here are the breakdown diagrams and Replacement parts for General Electric GTS22ICMBRWW Refrigerator | AppliancePartsPros.com
Jeffer
#3 Posted : Monday, August 23, 2010 2:50:57 PM(UTC)
Jeffer
NO Frost , Everything else works Great. it acts like when it go in to a defrost cycle it gets hung up.
#4 Posted : Monday, August 23, 2010 6:20:18 PM(UTC)
There is no defrost timer in your refrigerator. Everything (including the defrost cycle) is operated by the main control board which probably is the culprit.
- The main control board Part number: AP4436216
Jeffer
#5 Posted : Tuesday, August 24, 2010 6:34:03 AM(UTC)
Jeffer
Thank You for your help! Have a Blessed Day.
#6 Posted : Tuesday, August 24, 2010 1:21:00 PM(UTC)
refrigerator cooling problems (Refrigerator & Freezer Repair)
by san sewell 2/21/2016 12:23:32 AM(UTC)
Kenmore Coldspot Cooling problem (Refrigerator & Freezer Repair)
by TJStickel 7/10/2015 7:57:54 AM(UTC)
Kenmore Coldspot Cooling problem question (Refrigerator & Freezer Repair)
by TJStickel 7/9/2015 10:34:06 AM(UTC)
by zhogrider 9/2/2014 2:20:49 AM(UTC)
Maytag cooling problem (Refrigerator & Freezer Repair)
by Cdwig 7/31/2013 11:33:01 PM(UTC)
***frigidaire Side By Side Cooling Problems (Refrigerator & Freezer Repair)
by Cheeva316 6/27/2013 6:45:34 PM(UTC)
Fridge cooling problems (Refrigerator & Freezer Repair)
by luvmyfam77 11/23/2012 12:41:17 PM(UTC)
by lk15833 9/26/2012 7:19:47 AM(UTC)
by ronnysharma 7/27/2012 6:51:49 PM(UTC)
Frigidaire side-by-side cooling problems (Refrigerator & Freezer Repair)
by ChrisTN 2/9/2012 12:28:37 PM(UTC)
GE Side By Side Frig Cooling Problem (Refrigerator & Freezer Repair)
by thc888 12/23/2011 9:13:32 PM(UTC)
GE Arctica cooling problem (Refrigerator & Freezer Repair)
by thunderr 7/7/2011 7:19:04 PM(UTC)
Refridgerator cooling problem (Refrigerator & Freezer Repair)
by cmhaines 1/23/2011 6:12:55 AM(UTC)
Cooling problem freezer and fridge (Refrigerator & Freezer Repair)
by redr8er 7/21/2010 6:35:09 AM(UTC)
GE Side-by-side Cooling Problem (Refrigerator & Freezer Repair)
by hansen.gk 3/1/2010 1:59:12 PM(UTC)
