ronnysharma
#1 Posted : 13 years ago
ronnysharma
Hi there,
I'm having problems determining the cause for my Wine Cooler to not cool properly. When plugged in... all the fans are running. The temperature drops on the very bottom shelf of the fridge, but nowhere else. The compressor runs HOT. I put a mulit-meter on the relay switch prongs and the readings I got where 5 ohms, and 6.9 ohms. The condensor coils are clean...
Any suggestions.... I'm wondering if it's the compressor...
This is a Danby
DBC2760BLS
#2 Posted : 13 years ago
Seems like you have a bad compressor. I assume there is no evaporator fan, just a condensing fan. You can check inside the fridg for a vent and fan. If so, you might have an evaporator fan motor running backwards and not blowing any air.
ronnysharma
#3 Posted : 13 years ago
ronnysharma
There are actually 2 evaporator fans...
if you search for DG1-30, which is the compressor, you will be able to find a schematic. This is a dual climate wine cooler. I don't feel any air blowing when the fans are running... what are some possible causes for a fan to run backward, and would this be a reason for the compressor to heat up?
ronnysharma
#4 Posted : 13 years ago
ronnysharma
UserPostedImage
#5 Posted : 13 years ago
The fan motors are shaded pole,induction motors. Sometimes they get poled backwards from a power surge that opens a bias winding. You will need to get to each motor and check.
refrigerator cooling problems (Refrigerator & Freezer Repair)
by san sewell 9 years ago
by zhogrider 11 years ago
***frigidaire Side By Side Cooling Problems (Refrigerator & Freezer Repair)
by Cheeva316 12 years ago
Fridge cooling problems (Refrigerator & Freezer Repair)
by luvmyfam77 12 years ago
Frigidaire side-by-side cooling problems (Refrigerator & Freezer Repair)
by ChrisTN 13 years ago
GE Side by Side Bad Cooling Problems (Refrigerator & Freezer Repair)
by POKLET 16 years ago
Cooling problems with Amana side-by-side (Forum Announcements)
by tsears 16 years ago
