I have check all obvious stuff. supply hose filter screens are clear. lid switch is good. inlet solenoids are brand new. water level switch checked out good. What else could be wrong, not allowing flow and how do i check it??
What hoses do you have, are they the anti flood hoses? Take the hoses off the machine and make sure the supply water comes out.
the hoses are not plugged w/ anything. When hose installed and charge by opening supply valves on wall the hose changes position indicating pressurization. you hear the flow in hose but then dead end at solenoid.
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
Check for 120VAC to the solenoids while the timer calls for water.
there is power to solenoids but not every time pulling timer knob 'ON'.
Check for continuity the water temperature switch according to the wiring diagram. Here are the break down diagrams for the Whirlpool washer Model LSR7133KQ0Gene.
Gene, thanks for your part in trying to help me out w/ washer problem. Just a few minutes ago washer fixed. It turned out to be a 'stuck' water level switch. freed it up, now off and running! thanks again!!
