gimpy54
#1 Posted : Tuesday, July 1, 2008 10:25:11 AM(UTC)
gimpy54
I have check all obvious stuff. supply hose filter screens are clear. lid switch is good. inlet solenoids are brand new. water level switch checked out good. What else could be wrong, not allowing flow and how do i check it??
abadfish66
#2 Posted : Tuesday, July 1, 2008 11:51:22 AM(UTC)
abadfish66
What hoses do you have, are they the anti flood hoses? Take the hoses off the machine and make sure the supply water comes out.
gimpy54
#3 Posted : Tuesday, July 1, 2008 1:58:45 PM(UTC)
gimpy54
the hoses are not plugged w/ anything. When hose installed and charge by opening supply valves on wall the hose changes position indicating pressurization. you hear the flow in hose but then dead end at solenoid.
#4 Posted : Wednesday, July 2, 2008 1:47:38 PM(UTC)
Check for 120VAC to the solenoids while the timer calls for water.
gimpy54
#5 Posted : Wednesday, July 2, 2008 1:53:21 PM(UTC)
gimpy54
there is power to solenoids but not every time pulling timer knob 'ON'.
#6 Posted : Wednesday, July 2, 2008 2:00:38 PM(UTC)
Check for continuity the water temperature switch according to the wiring diagram.
Here are the break down diagrams for the Whirlpool washer Model LSR7133KQ0
gimpy54
#7 Posted : Thursday, July 3, 2008 10:20:13 AM(UTC)
gimpy54
Gene, thanks for your part in trying to help me out w/ washer problem. Just a few minutes ago washer fixed. It turned out to be a 'stuck' water level switch. freed it up, now off and running!
thanks again!!
A Couple of Problems, Dryer won't Heat / Washer won't fill with water (Washer Repair)
by gregjbutler 2/11/2013 4:14:21 PM(UTC)
washer won't fill with water. (Washer Repair)
by mikeshawver 4/21/2012 9:51:25 AM(UTC)
by Brandonks 3/8/2012 5:39:24 PM(UTC)
by colleenrclark 10/16/2011 4:20:46 PM(UTC)
GE Washer won't fill with water (Washer Repair)
by Nikon23 10/13/2011 7:40:41 PM(UTC)
frigidaire front load washer won't fill with water (Washer Repair)
by tponcsak69 8/14/2011 9:29:38 AM(UTC)
by elrodjo 8/6/2010 3:58:05 PM(UTC)
by muleyhunter 8/16/2009 1:44:35 PM(UTC)
Haier Washer won't fill with water (Washer Repair)
by bealcli 7/9/2009 11:19:49 AM(UTC)
Dishwasher won't fill with water (Dishwasher Repair)
by Tru2Chevy 6/26/2009 7:41:16 PM(UTC)
by peco 5/27/2009 8:37:59 AM(UTC)
woman in need of help washer won't fill with water (Washer Repair)
by lindavanzandt 11/30/2008 11:20:23 AM(UTC)
Whirlpool washer won't fill with water (Washer Repair)
by Evonne 10/22/2008 12:52:24 PM(UTC)
dishwasher won't fill with water (Dishwasher Repair)
by jhmorlang 2/6/2008 8:48:21 AM(UTC)
