3 Pages<123
#21 Posted : Friday, August 20, 2010 3:21:37 PM(UTC)
Originally Posted by: whalepirot Go to Quoted Post
...A power interruption has caused all but out oven lights to be inop. I am thinking either a power board component or one on the ERC, from the spike that got through...
Most likely the problem is a bad ERC (aka a clock/timer) but there is a small chance for the upper oven relay board to be bad as well because of the low voltage transformer integrated in the board. It's probably a good idea to order both parts and return unneeded later.
I found some troubleshooting instructions for this model which are attached to the reply.
- The ERC Part number: AP4283511
- The relay board Part number: AP4284825
Here are the breakdown diagrams and Replacement parts for JENN-AIR W256 Walloven - S/c Ele | AppliancePartsPros.com
File Attachment(s):
Jenn Air W256.doc (338kb) downloaded 6 time(s).
whalepirot
#22 Posted : Monday, August 23, 2010 8:17:16 PM(UTC)
whalepirot
Here are the breakdown diagrams .......
Thank you Gene, for ALL of that. Parts are ordered. Should I put just the relay in board first?
#23 Posted : Tuesday, August 24, 2010 1:28:04 PM(UTC)
You are welcome.
I would replace the ERC first.
whalepirot
#24 Posted : Saturday, August 28, 2010 6:07:27 PM(UTC)
whalepirot
I would replace the ERC first.Gene.
If I change the relay board first, the only one they sent, will it get damaged if the ERC turns out faulty?
We need our oven.
Despite being charged for both pricey boards, only one was sent with no notice of the other being back ordered, until the box arrived.
No expected ship date on the ERC. Not good customer service.
#25 Posted : Monday, September 6, 2010 2:09:18 PM(UTC)
We need our oven.
It is continued here: http://forum.appliancepartspros...r-power-interrupt-2.html
3 Pages<123
