seems like its not ice maker not getting water
First check to see if the water fill tube that is going to the ice maker has frozen shut at the end of it.
If you are sure that the tube did not freeze shut then you may need to replace the water valve.
Originally Posted by: ApplianceJunk  First check to see if the water fill tube that is going to the ice maker has frozen shut at the end of it.
If you are sure that the tube did not freeze shut then you may need to replace the water valve. how do i determine which water valve i need to replace there are two of them
