3 Pages<123
Joe / APP Team
#21 Posted : Wednesday, August 11, 2010 5:04:09 AM(UTC)
Joe / APP Team
Originally Posted by: markcongdon Go to Quoted Post
:) Thaks alot joe I will give it a try.
OK,
Let me know what happen's.
jimmyds
#22 Posted : Wednesday, August 11, 2010 5:56:15 AM(UTC)
jimmyds
dryer works fine but no heat? Keeps blowing the T.C.O I have put 1 new one on and it blow in about 20 min. Thanking it is the P.C.M. Does this sound right to you? Thank you.
Usually it's a Thermal switch that is no longer working properly or your heating coils or element is shorted out or burned out. Check ALL thermal temp controllers and heater coils for continuity.Sometimes the start resister will blow if the filter is stopped up or there is lint in the system causing overheating but this is not your problem there.I found one dryer once where a wire was rubbing the drum and shorted out and you guess it,NO HEAT!
markcongdon
#23 Posted : Wednesday, August 18, 2010 1:16:53 PM(UTC)
markcongdon
You have been a member since:: 8/4/2010(UTC)
:confused: Joe got my door switch in and it had the same ohms as the old one according to this site it should be differnt. thanks mark
http://www.servicematters.com/m...ibrary/docs/16026116.pdf
Originally Posted by: Joe / APP Team Go to Quoted Post
OK,
Joe / APP Team
#24 Posted : Wednesday, August 18, 2010 2:14:38 PM(UTC)
Joe / APP Team
Mark,
Recheck the switch circuits with the wires off, before you install it and connect the wires.
That doesn't make sense, unless the diagram is wrong from the manufacturer ?
:confused: :confused: :confused:
markcongdon
#25 Posted : Wednesday, August 18, 2010 9:46:54 PM(UTC)
markcongdon
:) Joe I checked it right out of the package it is weird.
Mark,
Joe / APP Team
#26 Posted : Thursday, August 19, 2010 6:41:28 AM(UTC)
Joe / APP Team
Mark,
Let's do this the old fashioned way...
Your door switch.
With the switch plunger out (like the door was open).
COM#3 to N/C #1 = closed circuit
COM#3 to N/O #2 = open circuit.
N/C#1 to N/O #2 = open circuit.
With the plunger depressed in (like the door was closed).
COM#3 to N/C#1 = open circuit.
COM#3 to N/O#2 = closed circuit.
If the switch circuits check out, install the switch and wire it up.
At the Main Control board.
Disconnect the Blue wire from the heater relay teminal(leave the black wire connected).
Start a timed dry cycle( with heat setting on high temperature).
(THIS IS A AC VOLTAGE TEST ... BE CAREFUL)
Check the heat relay terminal for 120 VAC out to the heater, to chassis ground.
Check the terminal of the blue wire for 120 VAC out of the heater, to chassis ground.
Let the unit run for a while, 10 to 15 minutes, and recheck the voltage again.
If they check proper after that, replace the control board.
There would have to be a problem in the board circuits when there is a voltage load on the system.
markcongdon
#27 Posted : Thursday, August 19, 2010 11:48:57 AM(UTC)
markcongdon
:) Joe give me some time I am still waiting on my back order parts. As soon as they come in I can do the test. The door switch did test the way you had. Thank you
Mark,
Your door switch.
Joe / APP Team
#28 Posted : Thursday, August 19, 2010 12:02:17 PM(UTC)
Joe / APP Team
Sorry,
I didn't know you were waiting on parts,
Waiting is not a problem,
Hope to hear from you soon, with a resolution for the problem.
Guest (8)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
3 Pages<123
