username
#1 Posted : Tuesday, June 24, 2008 5:27:11 PM(UTC)
username
Second fridge in the basement. Fridge not very cool, but freezer works. Freezer coils have some frost and one corner had large ice chunk that I removed. Evaporator fan not appear to be working and nothing block it. Door switch works and still does not activate fan. Also have water drips forming on ceiling of the inside fridge. For 1993 second fridge is it worth trying to replace fan or possible main control board. Is that the correct diagnosis? Or am I better off junking and buying new.
#2 Posted : Wednesday, June 25, 2008 4:56:20 PM(UTC)
Remove the rear cover and check if the compressor and the fan next to it are running. Post your findings.
Here are the break down diagrams for the Kitchen Aid refrigerator Model KTRS20MAWH01
username
#3 Posted : Wednesday, June 25, 2008 7:11:39 PM(UTC)
username
Yes, the compressor and fan are running.
#4 Posted : Wednesday, June 25, 2008 7:22:48 PM(UTC)
Clean the condenser coil (#3 on the unit break down diagram), wait about 24 hours and check temperatures inside both compartments. Post your findings.
username
#5 Posted : Saturday, June 28, 2008 10:20:20 AM(UTC)
username
Gene, It was pretty dirty and I vacummed it out from the front and the back. The temp in the fridge after 24 hours is still warm at 53.2. The freezer was on the coldest setting and it got down to -20 when I reset it to the middle setting and stopped measuring. What next?
#6 Posted : Sunday, June 29, 2008 9:07:42 AM(UTC)
Remove evaporator fan wires and stick 115 volts to the fan motor and see if it runs. If so, you will need a voltmeter to find the problem, might be a bad door switch.
If not, order a new evaporator fan.
GE GTH18ECTZRWW evaporator fan issue (Refrigerator & Freezer Repair)
by snakeeyesma81 4/30/2024 4:44:21 PM(UTC)
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Continuously running evaporator fan (Refrigerator & Freezer Repair)
by gjgogol 2/26/2024 6:47:30 AM(UTC)
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Crosley Freezer Evaporator Fan (Refrigerator & Freezer Repair)
by CP1 9/25/2022 1:16:25 PM(UTC)
How do I access GE Evaporator Fan, coils, thermistor, etc (Refrigerator & Freezer Repair)
by Yari 8/4/2022 1:48:47 PM(UTC)
samsung rf31fmesbsr evaporator fan voltage question (Refrigerator & Freezer Repair)
by jimmye4golf 7/20/2022 8:30:42 PM(UTC)
Evaporator fan only running (Refrigerator & Freezer Repair)
by jesus freak 5/17/2022 2:40:35 PM(UTC)
Evaporator fan blowing down (Refrigerator & Freezer Repair)
by Guest 1/18/2022 8:46:06 AM(UTC)
Kenmore evaporator fan cycles on and off (Refrigerator & Freezer Repair)
by kelly.kendrick@me.com 1/16/2022 1:43:06 PM(UTC)
Whirlpool WRX735SDBM00 fridge evaporator fan always on (Refrigerator & Freezer Repair)
by matmat 12/3/2021 8:25:59 PM(UTC)
U-Line Evaporator Fan Not working (Refrigerator & Freezer Repair)
by roscoej 10/5/2021 7:24:11 PM(UTC)
Noisy evaporator fan on subzero 650 (Refrigerator & Freezer Repair)
by DoctorG 8/5/2021 6:41:45 PM(UTC)
If you're evaporator fan constantly cycles on and off and never shuts down (Refrigerator & Freezer Repair)
by Guest 7/7/2021 10:42:26 PM(UTC)
