stberg@mchsi.com
#1 Posted : Friday, August 6, 2010 4:45:44 PM(UTC)
stberg@mchsi.com
My side by side Jennair fridge & freezer temp sometimes normal & has periods of warm cycles (very warm). It is not due to excessive use. It makes no clicking sound (relay switch). I have tried defrosting w/o success.The backside is relatively clean. The compressor is hot to the touch. Is there a temperature gauge that may be faulty?
Steve
#2 Posted : Saturday, August 7, 2010 11:03:24 AM(UTC)
Here are your parts,includes a wiring diagram.
Replacement parts for JCD2389GE models | AppliancePartsPros.com
[COLOR="Blue"]Is there a temperature gauge that may be faulty?[/COLOR]
Yes the temperature control thermostat (Item 3 in Section 2)
It is not uncommon for these to ge intermittent.
If the next time it happens you can get the compressor to come on by just fiddling with the temperature control then odds are this is the culprit.
Also if the condenser and evaporator fans are off when this occurs it could be that the unit is hanging up in the defrost mode.
Or
That the defrost heater is not being turned off by the defrost thermostst once all the ice has been removed from the evaporator coils and this extra heat is causing your temperature rise.
The above assumes that both the freezer and the fresh food sides are effected.
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus 10/7/2023 4:28:57 PM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Fridgedaire Refridgerator FRS241 (Appliance Parts)
by Dremcatcr 1/23/2022 11:15:03 AM(UTC)
GE gsh25jfxbww refridgerator (Refrigerator & Freezer Repair)
by David Heath 11/13/2021 4:10:59 AM(UTC)
Whirlpool refridgerator repair (Refrigerator & Freezer Repair)
by HectorMartinez 10/8/2021 12:22:46 AM(UTC)
Whirlpool Refridgerator (Refrigerator & Freezer Repair)
by mikecain01 10/7/2020 3:37:19 AM(UTC)
ge refridgerator not working (Refrigerator & Freezer Repair)
by geno630 9/10/2020 11:57:49 AM(UTC)
Freon leak in Viking refridgerator...repairable? what else can i do? (Refrigerator & Freezer Repair)
by viper_gts 7/29/2020 7:29:30 AM(UTC)
GE Refridgerator model PSS25NGNAWW (Refrigerator & Freezer Repair)
by shuskey450 7/18/2020 9:24:05 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
Fan Constantly Running on Viking Refridgerator (Refrigerator & Freezer Repair)
by deeni 4/7/2020 5:09:06 AM(UTC)
