Prototrax
#1 Posted : Sunday, June 22, 2008 7:57:23 AM(UTC)
Prototrax
Hello,
I have replaced the oven igniter and the oven still will not heat.
Top burners work fine and there are no codes displayed on the digital control panel.
Old igniter seems to test fine electrically.
My next idea in to replace the circut board (180.00):eek: !
As I understand the system, the gas will no start to flow unless the igniter gets hot and opens up the gas valve.
Prototrax
#2 Posted : Sunday, June 22, 2008 9:26:18 AM(UTC)
Prototrax
Second test..........
The broiler works.........
Voltage shows 6.0 volts going to the igniter.
But when I turn the oven on.........no voltage.
Whirlpool range oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by Guest 5/10/2021 12:58:16 PM(UTC)
Lower Oven doesn't heat properly (Oven Repair (including Ranges and Cooktops))
by Softballfan 4/16/2016 1:45:41 PM(UTC)
fridgidaire oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by debshroom 5/8/2013 7:15:43 AM(UTC)
upper oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by stephen36 2/25/2013 11:57:09 AM(UTC)
Oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by bobby6432 10/26/2012 3:28:27 PM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
by dskar 6/10/2012 5:16:27 AM(UTC)
by Silvernick 5/15/2012 8:20:59 PM(UTC)
oven doesn't heat to selected temp. (Oven Repair (including Ranges and Cooktops))
by jimsmithbc 10/31/2011 1:54:50 PM(UTC)
Magic Chef gas oven doesn't heat up (Oven Repair (including Ranges and Cooktops))
by jand 7/1/2011 9:23:12 AM(UTC)
Oven doesn't heat after bright flash (Oven Repair (including Ranges and Cooktops))
by markmelancon 6/17/2011 11:10:57 AM(UTC)
Electric Range oven doesn't heat - stove top works (Oven Repair (including Ranges and Cooktops))
by deannastevens70 3/2/2011 8:54:15 PM(UTC)
GE Oven doesn't heat after using self clean (Oven Repair (including Ranges and Cooktops))
by Elmo1 2/3/2011 4:57:50 PM(UTC)
GE oven doesn't heat up everytime (Oven Repair (including Ranges and Cooktops))
by IntermittentGE-Oven 12/20/2010 3:49:12 PM(UTC)
Magic Chef oven doesn't heat (Refrigerator & Freezer Repair)
by Francisco Dan 12/7/2010 12:46:57 PM(UTC)
