goinginsane037
#1 Posted : Saturday, May 29, 2010 1:58:07 PM(UTC)
goinginsane037
I have a whirlpool Dryer that I Bought used and now the control lock light will not turn off. I have tried unpluggin it from the wall and holding down the control lock button and the light still remains. What do you suggest I do or do I need to order the Control interface for it??? Thank you for your time.
sidfink43
#2 Posted : Wednesday, June 2, 2010 12:22:41 PM(UTC)
sidfink43
Look inside the top and see if there is a tech sheet which will show you how to put it in diagnosis/troubleshooting mode, and see if you can get an error code or some other determination of the problem.
goinginsane037
#3 Posted : Sunday, August 1, 2010 11:35:23 AM(UTC)
goinginsane037
I have looked and read over the manual and it says nothing about how to trouble shoot it. The light still comes on, on it's own and I'll getting aggrivated. DO you suggest I do anything else or should I have a tech come take a look at it???
sidfink43
#4 Posted : Sunday, August 1, 2010 1:05:18 PM(UTC)
sidfink43
Sounds like you are looking in the owner's manual and not the tech sheet.
Here is a link to the tech sheet for your model.
goinginsane037
#5 Posted : Wednesday, August 4, 2010 5:00:37 PM(UTC)
goinginsane037
Ok the link didn't come through and I can't find the tech sheet anywhere on the dryer. The owners must have no giving it to me. Can you still help me. I would greatly appreciate it. thank you
sidfink43
#6 Posted : Wednesday, August 4, 2010 6:17:16 PM(UTC)
sidfink43
No problem, see if this link will get you to it.
http://www.servicematters.com/d...0Sheet%20-%208558722.pdf
goinginsane037
#7 Posted : Wednesday, August 18, 2010 2:52:51 PM(UTC)
goinginsane037
Hey man I appreciate the help but I am still unable to get my dryer to start. I have ran through the whole tech sheet and according to it. I had to replace the Control Board so I ordered it and nothing happened same thing the dryer won't turn on. I have checked the motor and it's good. I don't want to give up but I don't know what else to do or what else to look for. Any suggestions???
sidfink43
#8 Posted : Wednesday, August 18, 2010 3:34:37 PM(UTC)
sidfink43
If it completely dead, try tracing the wiring to see if you are getting power to the main board. If you are, and still cannot get it to light up or come on, check all of your connections to the board and clean them and try again.
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
