MEMEM
#1 Posted : Friday, July 30, 2010 2:20:40 PM(UTC)
MEMEM
Four yr old GE side by side refrig /freezer. Lately freezer no colder than 18 degrees. Refrig seems OK. Any ideas.
#2 Posted : Friday, July 30, 2010 5:31:34 PM(UTC)
Check if there is a frost on the rear panel in the freezer.
Are the fan inside the freezer and on the back of the refrigerator working?
MEMEM
#3 Posted : Saturday, July 31, 2010 11:12:03 AM(UTC)
MEMEM
It's not frosted up. Fan not working. Compressor very hot.
#4 Posted : Saturday, July 31, 2010 7:42:26 PM(UTC)
I'm assuming the fan which is not working is the condenser fan (next to the compressor). If that's right, put an outside fan right away to coll the compressor and order the condenser fan motor and the main control board. They have to replaced together.
It is a good idea to clean the condenser at the same time.
- The condenser fan motor Part number: AP4265957
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Frigidaire Refrigerator FGHS2631PF4A - Freezer not cold but Refigerator side is fine (Refrigerator & Freezer Repair)
by kwaropay 1/28/2021 9:00:51 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
SidexSide Fridge/Freezer not cold; tried to self-diagnose (Refrigerator & Freezer Repair)
by kenroehr 2/1/2018 6:10:10 AM(UTC)
Refrigerator & Freezer Not Cold - Evap Coils Frosted Over (Refrigerator & Freezer Repair)
by gciccol 12/13/2017 1:32:46 PM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Non-defrosting upright freezer not cold on bottom (Refrigerator & Freezer Repair)
by KOP264 6/12/2017 4:38:01 AM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 2/11/2016 11:59:48 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
