lxk8
#1 Posted : Monday, February 22, 2010 4:08:12 AM(UTC)
lxk8
I can't figure out how to take the front off of my MAYTAG PYG2300AWW Gas Dryer. I need to replace the igniter and belt and I don't see how to get access. I can get he top to swing up but it appears that there are screws (on the inside) that hold the front to the sides. There doesn't appear to be enough room to get a screwdriver in there to back them out. Help!
headknocker
#2 Posted : Thursday, July 22, 2010 8:16:20 AM(UTC)
headknocker
I'm having the same problem. I assume you figured it out at this point:) What did you discover?
lxk8
#3 Posted : Thursday, July 22, 2010 8:28:27 AM(UTC)
lxk8
Still trying to figure it out. The igniter started working on its' own. I'm waiting for the belt to fail to force the issue.
headknocker
#4 Posted : Thursday, July 22, 2010 11:06:41 AM(UTC)
headknocker
Thanks for the quick reply. Did you ever get the front panel removed? If not, I figured it out around an hour ago. After prying up the top panel you simply remove the two upper screws holding the front panel to the side panels(one on each side) which allows the front panel to swing down. There's a hinge on the bottom of the front panel. The coils,igniter, etc. are right there when the panel is removed. Hope that helps.
Now I'm trying to figure out how to gain access to the rear of the unit as the sides and rear are one piece.
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Maytag gas dryer flame shuts off (Dryer Repair)
by Guest 11/13/2022 11:35:33 AM(UTC)
Maytag Gas Dryer Model # MGDB400VQ0 (Dryer Repair)
by lazyacre 3/29/2020 5:29:29 AM(UTC)
Maytag gas dryer won’t ignite (Dryer Repair)
by Jmuk_98 6/30/2018 9:47:34 AM(UTC)
Maytag gas dryer console (Dryer Repair)
by thorning 5/5/2017 4:32:55 AM(UTC)
Maytag Gas Dryer Burner won't stay lite (Dryer Repair)
by tseibring 1/26/2017 2:48:45 PM(UTC)
Maytag gas dryer not heating correctly (Dryer Repair)
by ifix325 12/10/2014 6:37:45 AM(UTC)
maytag gas dryer no heat (Dryer Repair)
by steve5024 11/8/2014 8:57:28 AM(UTC)
Maytag gas dryer belt keeps coming off (Dryer Repair)
by Blurr 10/29/2014 11:17:27 AM(UTC)
Maytag Gas Dryer Will Not Stay Hot (Dryer Repair)
by jschrote 8/27/2014 6:07:26 PM(UTC)
Maytag gas dryer heats only on high (Dryer Repair)
by broooklyn 4/9/2014 10:55:14 AM(UTC)
Maytag gas dryer - flame shuts off early (Dryer Repair)
by Dcarterlaw 4/1/2014 4:52:58 PM(UTC)
Maytag Gas Dryer Timer not Adance in Auto Dry (Dryer Repair)
by modcar40 3/4/2014 3:01:27 PM(UTC)
