Pastor Ken
#1 Posted : 15 years ago
Pastor Ken
When the oven is set, after a few minutes the preheat signal sounds but the oven element has never come on. And the oven is not hot. This began after a lighting storm where I had other problems so after checking a few things I replaced the control panel. Same thing. What next? I couldn't find a thermostat on the cutaway and the element (new this spring) appears to be fine.
#2 Posted : 15 years ago
Originally Posted by: Pastor Ken Go to Quoted Post
...1/ I replaced the control panel...
...2/ the element (new this spring) appears to be fine...
1/ I'm assuming you replaced the control board (aka a clock)?
2/ Have you checked the heating element for continuity?
Does the Broil work?
Pastor Ken
#3 Posted : 15 years ago
Pastor Ken
Got it! The element was severed behind the wall in the insulation. We're back in business. Thanks.
KN
Joe / APP Team
#4 Posted : 15 years ago
Joe / APP Team
Like you, I could not find a thermal fuse or hi limit switch on or in your range diagram. Most free standing ranges do not have them.
I take for granted when you "checked a few things" you also checked for burnt or damaged wires to the element ? and that both breakers set and supplying power to your range.
When you select broil on your control panel, does the upper element come on and heat? with a new control board and if the broil element does come on and heat, this would be a good indication of a damaged wire between your control board and bake element.
If neither element comes on and heats, it would be an indication of a power loss on one of your 120 volt lines to your range(outlet ,breaker,wiring or power cord) and may require an electrician to diagnose and repair as needed.
#5 Posted : 15 years ago
You are welcome Pastor Ken. We are glad you were able to fix it.
Whirlpool will not drain or cycle. No Obstructions. What next?? (Dishwasher Repair)
by RyGuy73 5 years ago
Fridge won't start, what next??? (Refrigerator & Freezer Repair)
by gefricot 9 years ago
Dryer still won't heat,what next? (Dryer Repair)
by BSTrue 10 years ago
Dryer--No heat, continuity tests ok...what next? (Dryer Repair)
by davesharpe 11 years ago
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 12 years ago
Ice covering evaporator coils . . . What next? (Refrigerator & Freezer Repair)
by Dale.1 12 years ago
frigidaire wont drain, pump replaced - what next? (Dishwasher Repair)
by mh1078 14 years ago
Maytag LAT5005AAE has new Lid Switch assembly but fuse continues to blow, what next? (Washer Repair)
by hankshiggs 14 years ago
Replaced defrost thermostat, what next? (Refrigerator & Freezer Repair)
by jesus freak 15 years ago
Maytag washer drain unclogged, what next? (Washer Repair)
by L. Caldwell 15 years ago
What next? (Washer Repair)
by AmanaLWM353W 15 years ago
Overload, Relay, Capacitor Replaced What Next? (Refrigerator & Freezer Repair)
by lrich002 15 years ago
What next??? (Dryer Repair)
by greeneyes49 16 years ago
Replaced defrost heater...coils frosting over again..what next? (Refrigerator & Freezer Repair)
by Momto8 16 years ago
GE Profile New Control Board...What Next?? (Refrigerator & Freezer Repair)
by gratefuldiver 16 years ago
